Re: 2 Questions, Fuel tank cleaning,a nd Oil Press
Posted by riverbend on March 16, 2005 at 06:59:55 from (208.160.34.252):
In Reply to: 2 Questions, Fuel tank cleaning,a nd Oil Pressure posted by Tanner Clark on March 16, 2005 at 06:24:34:
It depends on how much crud is in your gas tank. I had a similar problem and the nut and bolt approach worked for me.
Be sure to count the hardware that you drop in and use a variety of sizes. Put a couple gallons of water in the tank with the nuts and bolts. Just shaking the tank will get the big chunks out, they are causing most of the trouble. Dump out the dirty water. Refill with clean water and repeat until the water comes out clean. Then dump in a couple quarts of isopropol alcohol to remove the water.
Once the tank is clean, just keeping it mostly full and using the tractor regularly will prevent the problem from reoccuring.
Try a regular hardware store or a NAPA for the adapter fitting. You will need to take the line and the gauage with you.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
