340d axle leak
Posted by hank n' tx on March 16, 2005 at 18:16:27 from (209.184.25.108):
i bought a 340 desiel international recently. fluid was leaking from the outer center wheel. the cap was a little loose so i took it off and permatexed it and bolted back on. today i noticed quite a bit of fluid on the groung and it was coming from the axle housing. i figuire a bad seal. is that a difficult back breaking job? do i just take the tire off and unbolt the 4 bolts on the outer axle housing and the shaft will come out or what? any helpful info will be greatly aprreciated. also the tractor is a little hard to start.i have to hold the glow plug button in for a while and keep holding it in for a while after it starts till its stops sputtering. even after the tractor has run for awhile and you kill it and try to restart i have to hold the button in. is there anything i can do to make it start easier without useing ether.thanks hank
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
