Re: what are my options?
Posted by Dion on March 17, 2005 at 02:36:24 from (65.136.53.143):
In Reply to: what are my options? posted by haymeadow52 on March 16, 2005 at 22:53:33:
Since the easyout is hard, it will be brittle also. A sharp blow with another hardened punch may break it. MAKE SURE YOU WEARSAFETY GLASSES! Use a sharp pointed punch to increase the force of the blow.
I wish I had a nickle for every easyout or tap I have broken off.
A ram EDM will be expensive. There is a machine called a tap burner that does the same thing only slower. Many smaller machine shop have them because of the lower investment.
The only other method I know of is a dremel with a carbide burr. This is time consuming and requires patience. A dental pick will help get the pieces out after you cut it in half.
Good luck.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
