Re: Farmall M clutch
Posted by captaink on March 17, 2005 at 09:48:18 from (66.115.214.56):
In Reply to: Farmall M clutch posted by Chadd on March 17, 2005 at 09:39:02:
Yup, you should have the small clutch, and yup the belly pump comes out. Suggestions from me are to find a piece of concrete to park it on and a floor jack and another person to help get the belly pump out. Others have posted in previous threads some good ideas on how to get the pump out alone. Once the pump is out, the throw-out shaft needs to come out, the coupler on the drive shaft needs to come apart and the shaft removed. Take out three bolts that hold the pressure plate to the flywheel and put them in the three holes in the spring back plate that look like they don’t do anything. These holes actually end up in a threaded hole in the pressure plate and when screwed in will take the pressure off the clutch. Take out the other three and drop out the pressure plate.
I’d suggest checking the pilot and throw out bearings and consider replacing them. Check out the bolts holding the coupler together and the washers for wear. Check the transmission seals and replace as necessary.
Good luck!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
