Re: Easy Outs
Posted by Dion on March 17, 2005 at 09:52:41 from (162.74.52.185):
In Reply to: Easy Outs posted by Allan in NE on March 17, 2005 at 04:33:50:
Another point that may be of interest is how the easyout is rotated.
If a cresent wrench is used there will be unequal force applied to the easyout.
Use a tap handle that allows two hands. One on each side. As noted before, a feel is important.
The hole should be drilled in the center of the bolt. Grind the end until flat and center punch before drilling. Use a transfer punch if the bolt is broken below the surface. If it is a large bolt, use a large drill and easyout.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
