Re: Farmalls with Loader Break at Split Location
Posted by Haas on March 18, 2005 at 18:14:53 from (12.65.6.245):
In Reply to: Re: Farmalls with Loader Break at Split Location posted by Hugh MacKay on March 18, 2005 at 08:57:45:
Yes, you are correct, the casting would be vulnerable as well, maybe more so than the bolt. Same goes though, a joint tightly clamped with bolts is much stronger in the long run than one which has the bolts loose or even not tightened to specs. Bolts should always be torqued to the recommended working load(tension) for the bolt. Fortunately, most old tractors had lots of safety factor most places in the design and one or two bolts not torqued up made no difference. However, add heavy stress items like a loader and everything must be right.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
