Re: Wanting to Convert M to Have Live PTO
Posted by DWV on March 19, 2005 at 09:05:45 from (205.188.117.73):
In Reply to: Wanting to Convert M to Have Live PTO posted by Patrick Bryant on March 18, 2005 at 20:13:59:
Pat,im going to guess the mta engine is not in running shape.If you just want to fix up a handy tractor to use it not much of a problem if mta is good from clutch housing back.Just install the M engine,first put the mta clutch and flywheel on.
another problem to have hydrualics the mta pump needs put on M engine.Unless its a later M engine the front cover will need changed for direct bolt up.If M carb. is used choke rod will need little modifacation.If you want to use M hood put the M front bolster and steer shaft on also use lower radiator pipe from M.rear steer shaft needs to be mta.M starter won't bolt to mta.other small thing you can figure out.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
