Re: V-8 in an M, ever seen some good ones?
Posted by ChadS on March 20, 2005 at 06:31:54 from (4.224.132.212):
In Reply to: V-8 in an M, ever seen some good ones? posted by BuckCreekIH on March 19, 2005 at 14:22:37:
I guess you will have to pick which type of engine you want in the M bellhousing. Ford, Chevrolet, Chrysler, I ve seen lots of them. The chevy is pretty easy to do, just take the rear engine plate from the M, and find the center line for the drive shaft, drill the transmission mounting pattern in the M back plate. Use a chevy clutch and flywheel, and make your own throw out bearing that works for the chevy pressure plate. On the drive shaft, you can cut the M shaft in 2, and get the shaft from the 4 speed chevy tranny, cut both to length, and make an adapter coupler to fit the 2 halfs together. Starters,,, well you can use a transmission mounted starter, like the old powerglide trannys used, and it bolts on to the M's engine plate with 3 bolts. If the frame rails are in the way,, either notch them out, or use ones from a bigger series IH, like a 560, or from the 56 series tractors. They will bolt on to the M bellhousing. Chevys had a few different diameters of flywheels, so did ford, so where space is critical, look for the smaller diameter flywheels. it may help you utilize the space needed to mount a stock chevy, or ford starter to your V8 swap. My persoanla preference for engines would be MOPAR, lots of torque, fords #2 choice, Chevys # 3. Hope this helps,, ChadS
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
