Re: Farmall A will not start when warm
Posted by Red Dave on March 20, 2005 at 07:44:38 from (165.121.82.149):
In Reply to: Farmall A will not start when warm posted by Nicholas on March 20, 2005 at 06:15:59:
Not starting when hot sounds like a magneto issue. I'd start by cleaning it up and putting a new set of points in it. Gap them to .013
If it still won't start when warm, the magneto may need a coil. They can be bought at many parts suppliers, incuding this site, and aren't hard to install.
As far as starting it with 6 volts, it shouldn't be any problem at all. I have a B (same engine as yours) with oversized, high compression pistons in it and it starts fine, even in winter, with a 10 year-old 6 volt battery.
Unless you had your starter specially rebuilt for 12 volts, you probably won't need to do anything to it to go back to 6 volts. Those starters don't care about polarity, and will work just fine on 6 or 12 volts.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
