M oil pump ??
Posted by JonM on March 20, 2005 at 08:53:35 from (66.60.197.184):
I am working on an early M 25xxx, and have a parts tractor 34xxx, the oil pumps are pretty much the same except for the pressure regulating valve, on the running tractor the pump had a valve with part of the valve turned down smaller, on the parts tractor the valve had a set of 4 holes drilled around the top edge, which looks like it would let a small amount of oil pass through at all times, I realize oil pumps are easily changed out, but was just wondering if anyone could recommend which one to use, the tractor will be used in the field and pulled with a little. thanks Jon
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
