Re: 300 Utility Carb Rebuild
Posted by gascolator on March 20, 2005 at 14:08:03 from (151.197.212.40):
In Reply to: Re: 300 Utility Carb Rebuild posted by Ron Smith on March 19, 2005 at 19:08:16:
We had hard starting below 20. It was my
fault for ignoring everyone's advice and
not going through the ignition prior to
winter. Now she has new everything from
the rotor out to the plugs, she starts
great, provided you keep the throttle
shut and the choke out.
I have a nice 12V single-wire kit in the
box I was going to put on this spring.
(When we got the tractor it wasn't charging
but a new regulator from NAPA solved that
and meanwhile I'd ordered the 12V kit.) It's
working so well as a 6-volt negative ground
that I may not bother. It's become a case of
'it ain't broke.'
In the winter, we keep it on a trickle charger.
You lose too much charge in the cold. In the
other 3 seasons, it isn't necessary, as we
start it up and then go mow for two hours.
Anything above 1000RPM, the generator is
charging fine.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
