Re: Farmall B wiring
Posted by gene b on March 22, 2005 at 02:54:30 from (66.43.221.243):
In Reply to: Farmall B wiring posted by farmer ted on March 21, 2005 at 20:00:59:
The housing and the sw must be grounded to the steering post. Mite have to clean things up. I use a meter to check for ground. With engine running ground the field terminal on the generator to check the gen. Also if the original gen type is still there the third brush can be adjusted for current output.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
