Re: Super A steering, etc..
Posted by scotty on March 22, 2005 at 05:19:24 from (199.231.49.128):
In Reply to: Re: Super A steering, etc.. posted by Bill in VT on March 22, 2005 at 04:47:32:
Bill,
An RPM counter is nothing more than a hand held device that that can give you accurate RPM readings for anything that goes round and round. All kidding aside, they usually have a rubber pointer on the end that can be inserted into a center drilled hole such as your PTO shaft while tractor is running. They also have interchangeable diameter rubber wheels that can be held against known diameters to give RPM raediongs also. Allways use caution while doing these tests as you know the dangers of a rotating PTO shaft. I would recommend a helper be present.
scotty
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
