Re: Where can I get exploded views and part numbers?
Posted by D Slater on April 05, 2009 at 15:41:35 from (71.164.47.117):
In Reply to: Where can I get exploded views and part numbers? posted by bruce wayne on April 05, 2009 at 12:10:17:
Another way to look is go to www.cngco .com, then on the home page hit Case IH parts catalog. When that comes up, at model put H. Hit chassis then # 122 chassis steering mechanisem up. Go to # 43 and thats the felt. There not described very good, one says washer and the other calls it a spacer. Not all parts are the same on early H tractors to later ones and from the thrust bearing # you give the shaft you have to put in is for a newer tractor than 1940. Think the felt for your tractor is discontinued.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
