Re: First Farmall
Posted by Larry in CO on March 22, 2005 at 16:17:29 from (32.97.110.142):
In Reply to: Re: First Farmall posted by Mike3501 on March 22, 2005 at 14:47:53:
Mike,
I'm not sure what numbers you found. The serial number for an H should start with the letters FBK and the super H would start with SH. The serial number should be on an aluminum plate riveted on the left side of the bell housing. The valid suffixes for the H and M series are below:
X 1 Gasoline
X 1 A Gasoline – Low Speed Gears
X 1 B Gasoline – 5000 ft. Altitude
X 1 C Gasoline – 8000 ft. Altitude
X 1 E Gasoline – 5000 ft. Altitude – Low Speed Gears
X 1 F Gasoline – High Speed Gears
X 1 G Gasoline – High Speed Gears – Low Speed Gears
X 1 H Gasoline – High Speed Gears – 8000 ft. Altitude
X 1 J Gasoline – 7 m.p.h. High Speed Gears – 5000 ft. Altitude
X 1 L Gasoline – 5000 ft. Altitude – 7 m.p.h. 4th Speed – Low Low Speed
X 1 M Gasoline – 8000 ft. Altitude – Low Low Speed
X 1 N Gasoline – 8000 ft. Altitude – Low Low Speed – 7 m.p.h. 4th Speed
X 2 Modified
X 3 Kerosene
X 3 A Kerosene – Low Speed Gears
X 3 B Kerosene – 5000 ft. Altitude
X 3 C Kerosene – 8000 ft. Altitude
X 3 D Kerosene – High Speed Gears
X 3 G Kerosene – 7 m.p.h. High Speed Gears – 5000 ft. Altitude
X 3 H Kerosene – 7 m.p.h. Low Low Speed
X 4 Shop Mule
X 5 5000 ft. Altitude
X 5 A 5000 ft. Altitude – 7 m.p.h. 4th Speed
X 6 Low Speed Gears
X 6 A Low Speed Gears – Starting or Lighting
X 6 B Low Speed Gears – High Speed Gears
X 6 C Low Speed Gears – 5000 ft. Altitude
X 8 8000 ft. Altitude
X 9 High Speed Gears
X 10 10,000 ft. Altitude
X 11 Engines with Undersize Crankshaft
X 11 S Engines with Undersize Crankshaft (Service)
X 14 Starting or Lighting
X 14 A Battery Ignition with Starting or Lighting and Adjustable Front Axle
X 16 Over-Center Hand Operated Clutch
X 17 Distillate
X 17 A Distillate – 5000 ft. Altitude
X 17 D Distillate – 8000 ft. Altitude
X 18 Unlisted Feature
X 19 Special Transmission
X 20 Cotton Harvester
X 20 A Cotton Harvester – Gasoline
X 20 B Cotton Harvester – Kerosene
X 20 C Cotton Harvester – Diesel
X 20 D Cotton Harvester – Gasoline – Low Low Speed
X 20 E Cotton Harvester – Distillate – 5000 ft. Altitude
X 20 F Cotton Harvester – Gasoline – 5000 ft. Altitude Pistons
X 21 7 m.p.h. Transmission – 8000 ft. Altitude
X 22 Adjustable Front Axle (Heavy Duty)
X 22 A Adjustable Front Axle
X 23 Auburn Clutch
X 24 Nonadjustable Front Axle
Hope this helps.
Larry
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
