Re: Stumbling 706 gas
Posted by Bob M on March 23, 2005 at 11:38:01 from (151.190.254.108):
In Reply to: Stumbling 706 gas posted by Arc641 on March 22, 2005 at 19:28:27:
Your tractor is not getting enough fuel under load! If the carb has a drain plug at the bottom of the bowl remove it. (If no drain plug disconnect the fuel line where it goes into the carburetor.) You should get a SOLID stream of gasoline about the diameter of a pencil. A weak or dribbling stream says there’s a restriction in the fuel supply. Look for a plugged sediment bulb, trash in bottom of the tank blocking the fuel outlet, a pinched or kinked fuel line, etc. If the fuel supply flows OK then the problem’s with the carb. Might be as simple as the power screw is too set lean (open it up a half turn at a time and test). Could also be the bowl fuel inlet screen (if it has one) is plugged or there’s a blockage in an internal orifice or passage. Could also possibly be the float level set too low. You’ll need to go inside the carb to find and fix. Good luck!
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
