Re: M oilpan gasket!
Posted by RustyFarmall on March 24, 2005 at 07:35:42 from (199.120.81.218):
In Reply to: M oilpan gasket! posted by John M on March 24, 2005 at 06:17:59:
Like magman said, first make sure that the gasket surface is flat, those oil pans often get warped around the bolt holes due to someone overtightening the bolts. Also, make sure that all of the old gasket has been removed, along with the crud that is usually present. Gasket mating surfaces have got to be clean and flat. If all else fails, don't be afraid to use some silicon gasket sealer in addition to the gasket.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
