Re: Belt tension?
Posted by Bob M on March 24, 2005 at 11:17:03 from (151.190.254.106):
In Reply to: Belt tension? posted by Andrew Z on March 24, 2005 at 10:30:59:
Andrew – If the belt’s slipping even when it’s tight it’s probably glazed or greasy. It should be replaced.
When you get the old belt off use paint thinner or spray brake cleaner and thoroughly clean both sheave grooves to remove any trace of grease, antifreeze, etc which will make even a new belt slip.
It doesn’t take much tension to for a good belt to grip – even if it’s pulling an alternator. About 1” to 1-1/2” of deflection with finger pressure applied midway between the sheaves is right. (Or if you can grab and turn the fan blade a bit by hand and the crankshaft follows, the belt's plenty tight.)
Don’t overtighten the belt! It only causes rapid wear on the fan hub bearings, and is hard on the belt too.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
