Re: Belt tension?
Posted by Bob M on March 24, 2005 at 12:48:35 from (151.190.254.107):
In Reply to: Re: Belt tension? posted by Allan in NE on March 24, 2005 at 11:29:17:
Hi Alan – Belt slippage has nothing whatsoever to do with which side of the engine an alternator is mounted. Rather it’s belt tension and pulley wrap that matter.
But.....you are indeed correct about in the “old days” belt slippage was less of a problem. The reason for this however is alternator output capacity, not which side of the motor the the alternator happened to be positioned.
Explanation: Back in the early 60’s when they first appeared on cars and tractors, most alternators had a maximum output of 25 - 30 amps or so. This required about 1/2 HP to drive at full load – well within the capacity of a single 1/2” V-belt.
Fast forward a few years and you’ll find alternator capacities have increased. The 80’s era, internally regulated Delco alternators (the preferred unit for 12 volt conversions) are rated usually 55 or 61 amps. This alternator needs 1-1/4 HP or more to drive at full output – about the limit of a single V-belt. Therefore if the belt is not tight, or it’s oily or wet, it’s gonna want to slip under heavy load - like immediately after starting the engine.
Today cars are now routinely supplied with 90 to 120 amp (and larger) alternators. And these are universally driven by multigroove serpentine belts to deliver the 2-1/2 HP+ it takes to spin ‘em at full load. Further, unlike V belts, serpentine belts are “threaded” around a series of accessory, tensioner and idler pulleys at the front of the engine to achieve a 180+ deg belt wrap around each pulley in order to enhance the belt’s grip. And there’s always a spring loaded tensioner to keep the belt tight as is stretches.
Bottom line is with regard to belt slippage it doesn’t matter where the alternator is positioned on the engine – it’s the layout of the belt drive that counts! ...Bob
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
