Re: Transmission Cover--your thoughts
Posted by Chris in Fredericton on March 24, 2005 at 15:17:09 from (69.195.193.243):
In Reply to: Transmission Cover--your thoughts posted by Charles Park on March 24, 2005 at 07:48:29:
Charles.... It can be easily done with two people. Once you pry up on it to free it up from the gasket and gunk, get in a good position behind the rear axles and lift straight up, remember your three shifter rails/forks are dangling from underneath. You don't want ding these as you move it up an out. Maybe you're completely removing your gas tank first??... you could just remove the front tank support and then tie that end up to a rafter or something above. Just removed my cover to get at the shifter rails; four out of my five detente springs were shot. It's a great opportunity to get a good look at other problem areas and to see just how every is put together in the tranny.Good luck.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
