Re: Farmall M won't start.
Posted by El Toro on March 24, 2005 at 16:40:20 from (205.188.117.73):
In Reply to: Farmall M won't start. posted by Jamie Stratton on March 24, 2005 at 15:18:35:
If you loosen the starter bolts as NDS has suggested and the bendix isn't stuck. Double check all your battery and clean all battery connections. Are you sure the battery is fully charged? If the battery charge is ok and still won't crank. Disconnect the battery ground and pull the starter off the tractor and reconnect the battery ground. Short across the solenoid with a screwdriver to see the bendix is energized. Just touch it for a moment to see if the bendix flies forward. Keep hands, fingers and clothing away from the pinion gear while doing this. If this checks out ok see if the engine can be turned with a crank or bar. If there's a ballast resistor in the ignition circuit I would replace it. If the tractor starts while cranking, then dies, is good indication of a defective resistor. Good Luck, Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
