Re: Transmission Cover--your thoughts
Posted by kfox on March 24, 2005 at 19:34:44 from (63.18.236.62):
In Reply to: Re: Transmission Cover--your thoughts posted by Nebraska Cowman on March 24, 2005 at 10:39:35:
I just took mine off a H a couple of days ago. The front end was cracked at the rear of the belt pully opening. Been thet way for years it looks like. Their are 3 dowl pins in the case, and the crack was in the front dowel hole. I thought it was just a minor grease leak before I took it apart. After I got the belt pully box off and saw the crack, I started working from the front toward the back. I got it up high enough to get 4- 7/16 nuts under the cover and then screwed 12 inch pieces of 7/16 all-thread into the case, and through the nuts Then I used the nuts for jacks so I could raise the cover. I evenly. It took a little longer, but I'm a one man operation, and that cover is pretty heavy. Also didn't want to finish breaking the cover.
ken fox
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
