Re: MTA rear end housing ?
Posted by Wardner on March 27, 2005 at 20:17:54 from (4.154.243.14):
In Reply to: MTA rear end housing ? posted by TWL on March 27, 2005 at 17:15:02:
I have done that swap in reverse to install a 400 fast hitch on a SMTA. In order words, I put a 400 lid on a SMTA tub.
You should have no problems. If it were me, I would change out the tub and lid and find a fast hitch to go with the new parts. The 400 lid will need several holes drilled to accept the steering post of the SMTA.
While I was at it, I also put 560 gears and bearings in the tractor. I wanted the slower first gear as well as the slower ring and pinion of the 560. I didn't need to change out the bearings but I noticed they were bigger and I assumed better. I now have a SMTA that creeps in first gear low range and has a top speed around 11 MPH. Perfect.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
