Re: Farmall 300 wont start
Posted by El Toro on March 28, 2005 at 04:28:05 from (205.188.117.13):
In Reply to: Farmall 300 wont start posted by G Vestal on March 27, 2005 at 18:30:29:
When were the sparkplugs changed? Remove a plug
and ground it against the engine block with the
sparkplug wire connected. Then crank over the
engine with ignition switch on to see if that plug is firing. If it is firing, check the firing order 1-3-4-2, look at the rotor to see which way the rotor turns, probably CW.
If you have fire through the plug and still won't start remove No1 plug near the radiator and have someone crank over the engine while you hold your thumb over the hole until you feel compression. Then rotate engine until timing marks are in alignment. Do this slowly, then look at your rotor it should be pointing to NO1 plug wire in the cap. Make sure you feel compression against your thumb since you need the engine on that stroke because distributors or mags are installed with engine on this stroke. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
