Re: Farmall H Transmission
Posted by Chris NW Ind on April 05, 2009 at 16:47:29 from (64.136.27.229):
In Reply to: Farmall H Transmission posted by Alakshak on April 05, 2009 at 15:47:51:
Stalls the engine in gear AND in neutral.... I'd do what the other guy says and pull the belly pump and check all the clutch connections first. That's easiest.
However, I doubt your problem lays outside the trans. Pull the belt pulley or delete cover and look inside. You'll see the input shaft, the sliding gears, and part of the countershaft assembly. When in neutral, the only things turning are the input shaft assembly, counter (bottom) shaft and reverse idler.
Chris B.
