Re: B414 Hydraulic flush
Posted by JB2 on March 29, 2005 at 21:46:41 from (24.157.143.220):
In Reply to: B414 Hydraulic flush posted by Eric Rylander on March 29, 2005 at 18:47:09:
Hi Eric, the filter is in the return line in the front of the reservoir under the seat. When you sit on the seat and look down at the top of the transmission cover between your legs on the right side you will see two steel hydraulic lines from the hydraulic pump to the reservoir. The small one is the pressure line and the large one is the return/suction line. The filter is on the end of the suction line in the reservoir. To remove the filter without loosing Hytran fluid, park the tractor on a steep incline with front pointing up. Lock parking brake, turn engine off and put transmission in reverse gear LO range. On the suction line, about 6 inches from the reservoir you will see a rubber sleeve with two hose clamps on it. Clean all the dirt from this area, loosen hose clamps and slide rubber sleeve forward on the suction line until the joint in the suction line is exposed. The suction line towards the reservoir has a slight curve to it, now rotate this section of the suction line until the curve allows this section to be clear of the section to the hydraulic pump. Now carefully pull the section in the reservoir towards the front of the tractor. Becareful to pull in a straight line as not to damage the filter screen that will come out of the reservoir. Clean filter screen with solvent and dry. Put some lubricant on the "O" ring seal and re-install in reverse order. Hope this helps. Can't remember Hytran capacity. The fluid can also be drained from the suction line by putting a piece of flexible hose on the suction line into a container. To drain the system you would not park the tractor on an incline. Good Luck JB2
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
