Re: Tachometer Diference 4 cyl to 6 cyl?
Posted by Hugh MacKay on March 30, 2005 at 04:22:58 from (209.226.247.77):
In Reply to: Tachometer Diference 4 cyl to 6 cyl? posted by Migraine on March 29, 2005 at 20:52:05:
Migraine: Those tachs were all cable drive and as I recall, at least the diesels were driven off the cam shaft. There was however gears between shaft and where cable hooked on, thus one would have to know that ratio as well.
Don't think 4 or 6 cylinder will make bit of difference. Series of tractors between doner and recieptiant will probably have more bearing on the match. Just as an example 504 with D-188 engine is just 4 cylinders of a D-282 used in 560 and 656. I'd be willing to bet those tachs are identical. Your 400 comes from another blood line.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
