if engine isn't overheating or blowing coolant out of overflow,pull oil cooler an check it if no problem is found remove oil pan then look around the bottom of liners after engine has been sitting for a reasonable amount of time if no leak is found hook a radiator pressure pump up to radiator an pressurize it an check again
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
