Re: Farmall H Transmission
Posted by D Slater on April 05, 2009 at 17:01:38 from (71.164.47.117):
In Reply to: Re: Farmall H Transmission posted by Alakshak on April 05, 2009 at 16:41:35:
No need to remove unit, just the drive coupling unless you find the problem is it. In case something is jamed between gear teeth you could try putting the pto in gear and see if it will turn the opisite way from normal. Still would need to correct problem though. Another thing to check after removing whatever is covering belt pulley drive opening, is where main shaft goes into input shaft. See if any of the rollers from bearing have came out and jamed gears or see if main shaft will move up and down very much inside input shaft.
