Re: 400 Farmall Power Steering Part III
Posted by Bobcat on March 31, 2005 at 08:18:57 from (69.66.83.148):
In Reply to: 400 Farmall Power Steering Part III posted by grubby on March 31, 2005 at 07:06:49:
Does the diverter valve itself show wear? If it leaks at the ends it will act like that. I asume this is a factory power steering unit. I went through this on a 450 that had weak steering unless one of the hydraulic levers was pulled then it was 1 finger steering. That valve is located under the regulator valve. Can be pulled in a couple minutes to check. I had to have a new one machined as they are not avaluable. Hope this is your fix because they can steer really well no matter what weight you are picking up!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
