Re: Installing Wet Sleeve Liners
Posted by K.B.-826 on March 31, 2005 at 16:33:39 from (68.115.110.249):
In Reply to: Installing Wet Sleeve Liners posted by Carp on March 31, 2005 at 13:49:06:
John Deere makes a special soap to lubricate the o-rings. Your local dealer should have it on hand, or will be able to get it for you. Before installing the o-rings, test fit each sleeve and measure how far each one sits above the deck of the block, move them around to get as close to the specification in your manual as possible. After you get the sleeves installed, screw some bolts with washers into head bolt holes to hold the sleeves in place as you rotate the engine finishing reassembly.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
