Re: H Timing
Posted by El Toro on April 01, 2005 at 04:00:03 from (205.188.117.13):
In Reply to: H Timing posted by Tailhunter on March 31, 2005 at 16:01:38:
Is your distributor installed incorrectly? If it is go to page 9 on this forum and look for Chris Willy's posting on a Farmall M that needed help
with a distributor problem and read my posting
if your distributor has been removed.
If you just need to check the timing and the tractor is running I use a timing light. You just
connect lead to No1 plug wire near the radiator and hook up the timing light to a battery. Put some chalk on the first timing mark on the damper pulley. Let the engine idle and hold timing light on timing pointer. If it is off loosen
distrbutor bolt enough so you can move it. Move
distr slightly so marks are aligned. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
