Re: Anybody,...clutch bearing?
Posted by PAULIH300 on April 01, 2005 at 20:04:34 from (152.163.101.13):
In Reply to: Anybody,...clutch bearing? posted by iester on April 01, 2005 at 19:45:26:
The trans input shaft goes thru the bearing,clutch disc and pressure plate and into the crank pilot bearing.There is no way to remove a full circle bearing when a shaft passes thru its center....without removing the shaft first.And the only way to do that is to split the tractor.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
