Re: STUCK M
Posted by fox on April 02, 2005 at 04:59:18 from (68.76.166.193):
In Reply to: Re: STUCK M posted by El Toro on April 02, 2005 at 03:55:08:
If the head is still on it, drain the coolant, hook it up to a water heater and let the hot water run thru it. While this is going on, get the plugs out and put some Pb blaster or something like it in each plug hole.
Jack up onw rear wheel and put it in 5 th, then rock it back and forth.
The heat form the water is the cure.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
