Re: FArmall 300
Posted by skipper on April 02, 2005 at 18:26:11 from (4.41.5.202):
In Reply to: FArmall 300 posted by EWA on April 02, 2005 at 15:49:39:
EWA
I have the original owners manual that came with my 350 Farmall.
For the live PTO it says use 2-qt SAE 10W.
For trans/diff W/TA: 7-gallon SAE-75 gear lube, OR 1-qt IH TA Transmission lube additive to each 4 gallon of either SAE-10 or SAE-10W engine oil. When temps are consistently above +40F SAE-80 gear lube may be used.
For trans/diff wo/TA: use SAE-75 or SAE-80 gear lube. same mixture as above may substitute or above +40F SAE-90 gear lube may be used.
Having written all that, most guys use straight IH HyTran in all the above componets, mostly because of the ability to hold moisture over a long period of time, I believe and the dealers do the same.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
