H frt end shimmy
Posted by Mikw ISW on April 02, 2005 at 19:06:45 from (205.188.117.73):
Got my "48 H gassed up and went out for a ride today. But the shimmy in the steering has me concerned and I'm looking for suggestions. I've replaced the bushings for upper pivot shaft and the bearing at the end of the worm shaft. The u-joint is new also. The pivot shaft is new after market. The castle nut on sector gear tightens up so far that it pinches the gear to the upper bolster and makes steering almost impossible. This new shaft must be wrong? I still have the old one. Going to disassemble Sunday and see what I find. I also see some side to side movement in shaft as I turn steering wheel. All help appreciated, Mike
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
