Re: Breaks Manuals
Posted by gene b on April 03, 2005 at 18:59:09 from (66.43.221.243):
In Reply to: Breaks Manuals posted by nicholas1836 on April 03, 2005 at 09:51:11:
You probably will need to replace both seals. The drivers side is not easy to replace the inner seal as the platform and clutch and left brake pedal assy have to be remover for the inner seal. Outer seals arent that hard. You can get new linning at a brake shop and rivet them on the bands and save 50 bucks or so its your money.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
