Re: H not starting UPDATE
Posted by gene (Missouri) on April 03, 2005 at 20:21:34 from (208.144.172.145):
In Reply to: H not starting UPDATE posted by Rich Iowa on April 03, 2005 at 14:07:14:
Fully charge the battery up then let it set for an hour or so. Hook your voltmeter to the battery - check the battery voltage. With the voltmeter still connected crank the engine. Check the battery voltage while cranking. You are checking the voltage drop.
For a fully charged 6 volt battery (6 to 7 volts), if the voltage drops to around 5 volts or lower during cranking you are due for a battery.
Post a Followup
