Re: SA update question
Posted by Stan(VA). on April 04, 2005 at 05:05:03 from (208.59.156.74):
In Reply to: SA update question posted by Greg-N-CA on April 03, 2005 at 16:43:05:
Gene is right in that it is probably a replacement engine block, but it is off of a Farmall C. FCM is the farmall C engine prefix (FAAM would be on your original engine), the G suffix has been bantered about on here before general assumption seemed to be Gas engine. The blocks casting number behind the oil filter should be 251069. Unless someone has modified it in the past, the replacement sleeve set should be the 3 1/8" overbore Sleeve and piston set with a 3 5/16" OD where the O-ring seals near the bottom of the sleeve. It's worth pulling a sleeve and measuring to be sure before ordering.
Stan(VA).
Post a Followup
