Re: Lift all pump
Posted by the tractor vet on April 04, 2005 at 08:22:28 from (4.124.84.102):
In Reply to: Lift all pump posted by Zach Perry on April 04, 2005 at 07:20:46:
Ok , here is how you make the special tool for pump drive removal (1) get a pice of 1/2 inch key stock and cut it to be as wide as the drive is round. (2) find yourself and old nut say aleast 3/4 inch out side if you are a good welder weld the inside of the nut to the key stock with the nut layen flat aginist the keystock if you are not a good welder then take the nut and key stock to a welder and have him zap it together then you use and impact wrench and buzz it off . Now this morning for the life of me i can't remember if it is left hand threads on that or right hand I keep thinking left. Need a second cup of coffee .
Post a Followup
