Re: Super M Clutch Removal
Posted by Andy Martin on April 05, 2005 at 05:37:24 from (64.219.39.195):
In Reply to: Super M Clutch Removal posted by colekicker on April 04, 2005 at 22:28:57:
The clutch disc will come out but not the pressure plate on the SM but not on the SMTA.
Clean the inside of the cavity and remove everything you can. There is just enough wiggle room to get the clutch disc out. Make sure you have the pressure plate compressed by putting the three mounting bolts in the holes to compress the pressure plate.
If you need the pressure plate out you'll need to split the tractor.
Post a Followup
