Re: Gas Gauge
Posted by Allan in NE on April 05, 2005 at 12:59:35 from (148.78.243.26):
In Reply to: Re: Gas Gauge posted by chadd on April 05, 2005 at 12:49:55:
Yep,
Most of 'em have three terminals, but one is just a ground for the case. Don't ground that 12 volt feed or you'll warm 'er up.
Ground the sender terminal.
Allan
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
