Re: 3 bolt starter wireing
Posted by Tramway Guy on April 05, 2005 at 15:40:57 from (24.58.204.26):
In Reply to: 3 bolt starter wireing posted by Tedd on April 05, 2005 at 15:07:12:
The one marked 'S' should be the one that the wire from the starter switch is connected to. The one that goes to the on-off switch is usually connected to the upper large post on the starter - this connects the battery to the rest of the electrical system. However, it should be have a very large ring terminal on it. If it doesn't and you know that it has not been broken off or something, then you need to carefully trace this out because something may have been modified on this particular tractor.
The one marked 'R' is to bypass the ballast resistor when the starter is cranking, thus giving the ignition coil more voltage. You may or may not be using this particular feature.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
