Re: Farmall Cub (proud new owner)
Posted by Andrew Z on April 05, 2005 at 19:27:58 from (64.252.226.127):
In Reply to: Farmall Cub (proud new owner) posted by GNB on April 05, 2005 at 19:18:54:
If you got the head off I would have the valve guides check out they may need to be replaced. Alot of them have worn guides due to running regular gas for "X" amount years.
Andrew
Post a Followup
