Re: Bob M, update on charging woes
Posted by Bob M on April 06, 2005 at 04:44:30 from (151.190.254.108):
In Reply to: Bob M, update on charging woes posted by Paul Shuler on April 05, 2005 at 22:41:27:
Hi Paul!
Something is causing a current drain from the regulator L terminal when the L wire is connected. Suspect messed up wiring inside the switch box, or possibly the light switch itself is bad.
If your tractor doesn’t have lights you can simply leave the L wire disconnected and leave it that way. Or if you are feeling ambitious you can try to track down and correct the fault.
Note – Since you now have a voltage regulator, the L and H positions on the light switch are now simply two “off” positions for the lights. L and H should otherwise have no effect on the charging system operation.
Snow has pretty much melted here though there's still some piles left in the shade. PLENTY snowmelt however – many of the low-lying fields are under water right now. ...Bob
Post a Followup
