Re: Farmall Cub (proud new owner)
Posted by El Toro on April 06, 2005 at 06:16:29 from (205.188.117.73):
In Reply to: Farmall Cub (proud new owner) posted by GNB on April 05, 2005 at 19:18:54:
The cylinder head is as the MagMan described. The valves are located in the engine block. Those engine aren't sleeved, but they can be bored
oversize. If the cylinders are very rusty and pitted I would take the block to a machine shop
that you know, that does good engine machining
after you get the pistons out and have the valves ground and the crankshaft measured for wear. Hal
Post a Followup
