Re: Ticking noise in my H governer
Posted by RustyFarmall on April 06, 2005 at 12:34:03 from (207.32.13.252):
In Reply to: Ticking noise in my H governer posted by farmalljim10 on April 06, 2005 at 12:24:17:
The governor is oiled intermittently from the engine, sort of a splash system, so engine oil pressure would not really apply here. There is a bearing in the gov which could be failing. About the only other thing that could create a ticking noise would be the gears that drive it, possibly a chipped or broken tooth on either the drive gear or the driven gear. Could also be something as simple as a misplaced cotter pin. The only way you will know for sure is to remove the cover and take a peek inside. You may need to remove the whole thing from the engine and take it apart. On the other hand, if the ticking isn't real loud, maybe just live with it?
Post a Followup
