Re: Ticking sound in the rear end on my 44 H?
Posted by Bob M on April 07, 2005 at 11:10:55 from (151.190.254.106):
In Reply to: Ticking sound in the rear end on my 44 H? posted by Tanner Clark on April 07, 2005 at 10:10:54:
Tanner - See if the sound goes away when the clutch depressed and the tractor is stationary. If the sound disappears, remove the tin dust cover under the tractor between the belly pump and the transmission. Then look for loose bolts or worn out rubber bushings at in the transmission input flex coupling. Also check for radial slop in the input shaft (indicating a worn bearing). Note: You'll need to remove the belly pump drive shaft to access the coupling - slide the end collars toward the center pf the shaft and the shaft will drop out of the drive dogs. If everything at the input shaft looks good try running the tractor with the belly pump drive shaft removed. Sometimes a worn drive shaft or tired pump will make odd ticking and clunking sounds when they are spinning....
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
