Re: Alternator Hits H Hood
Posted by REDEYE on April 07, 2005 at 15:24:59 from (67.191.143.73):
In Reply to: Alternator Hits H Hood posted by RWB on April 07, 2005 at 15:13:47:
im guessing it is a larger "gm" style or similar. if you used the same mounting bracket that used to mount the generator you should still be able to mount the alternator. you have to get a shorter belt and rotate the alternator untill it is almost touching the valve cover and then it will clear the hood. modification to the belt tension bar is needed as well. or you could go with a forien alternator as they are usually smaller.
Post a Followup
