Re: Farmall B won't start
Posted by Okla Kansan on April 07, 2005 at 17:44:09 from (209.240.205.63):
In Reply to: Farmall B won't start posted by BigTex on April 06, 2005 at 15:27:12:
yup, if you got gas running outa the carb , its another problem, but, if thats the IT problem, its relatively easy to fix. First shut off the gas at the tank. If you cant do that, then youll have to buy a new gas bowl assembly. Next, buy new spark plugs. Now, it should start normally, BUT, when done with it, shut the gas OFF, and let it run for a minute before killikng it. I got a 48 Cub, and i had to replace the fuel bowl assembly as it wouldnt shut off, and flood the carb, and flood out the plugs. Once that happens, you cant hardly reuse them. Ive taken a torch to them to try to dry them out, dosent work. BUT, new plugs aint that high, and if you remember to shut her off every time you shut her down, youll be alright. I got a 41 B also
Post a Followup
